Date/Time: Wed, 25 Nov 2026 22:08:13 +0000
Sierra started crashing randomly.
View Count: 596
| [2025-04-22 14:46:52] |
| TLinzer - Posts: 3 |
For some reason my SC has started to crash the past 2 days when im either entering a trade or am in a trade. I have checked logs and dont see anything that would stand out to me being an issue, but maybe Im missing something. Would love some assistance on the topic. Thank you |
| [2025-04-22 15:24:56] |
Run Sierra Chart in Safe Mode and see if you have the same issue. In Safe Mode custom studies do not work. If you do not have a problem in Safe Mode, then this would point to a custom study that is causing an issue. You would need to determine the particular study and figure out why it is causing an issue (or contact the developer and have them look into it). Refer to the following: Sierra Chart - Software Login Instructions: Using Safe Mode For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
