Date/Time: Wed, 25 Nov 2026 22:20:48 +0000
Repeated levels in Numbers Bar
View Count: 626
| [2025-04-16 21:04:34] |
| User447011 - Posts: 7 |
Hi, I see some consecutive levels with exactly the same numbers on both bid and ask side, see the attached figure. Is that because the 0 are filled by the neighbor levels? |
Attachment Deleted. |
| [2025-04-16 21:14:32] |
Make sure your "Intraday Data Storage Time Unit" is set to 1 tick. Refer to the following: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) If it is already 1 tick, then the issue you are having is due to your data provider. You will not have this issue with the data from our Denali Exchange Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-16 21:39:59] |
it's find after I delete and reload the data, thanks!
