Date/Time: Thu, 19 Nov 2026 11:17:22 +0000
Not Connecting To Data Close event error. Windows error code 10053: An established connect
View Count: 687
[2024-12-09 15:14:34]
User303857 - Posts: 201
Thank You
Date Time Of Last Edit: 2025-08-25 06:25:29
[2024-12-09 16:13:09]
This is not a complete log, we cannot help with that.
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
[2024-12-09 16:34:52]
Date Time Of Last Edit: 2025-08-25 06:25:41
[2024-12-09 16:40:07]
Thank You
Date Time Of Last Edit: 2025-08-25 06:26:03
[2024-12-09 19:18:38]
A few items of note:
1) You are connecting to Rithmic, but your symbols are setup for Teton. Make sure you update your symbols when you change services. At this point, select "Edit >> Translate Symbols to Current Service" in order to update your symbols for the service you are connected to. Also refer to the following:
Rithmic Trading Platform Service: Frequent Reconnections
2) You went from a more recent version to a somewhat older one (your log shows you on v 2684), which is why you are showing errors regarding your Chartbooks. We recommend updating to the latest release (version 2719). And then staying on that version and if you have a problem, let us know what it is so we can help you work through it.
[2024-12-09 19:32:03]
In addition to the above response if you have an issue with Sierra Chart freezing or becoming unresponsive from a Chartbook, refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook
