Date/Time: Wed, 25 Nov 2026 21:45:57 +0000
Video Guide - How to move Sierra charts around like TradingView
View Count: 3460
[2024-11-24 17:29:30]
Calculus - Posts: 153
Sierra is a far better charting program than TV, but nevertheless TV can/does a few things better than Sierra.
I've always liked how one can move the charts around in TV but never worked out if it was possible to do the same with Sierra.
This video explains exactly how it's done, and it's great.
https://www.youtube.com/watch?v=PvUv6t86gNc
The fella making the vids also has loads of other Sierra tips and tricks.
[2025-05-14 15:01:03]
juicebro - Posts: 119
Here it is in 3 steps:
1. Enable the hand tool to pan vertically
Chart Drawing Tools: Vertical Movement and Scaling
2. Right click on the price scale and click
Interactive Scale Range
3. Right click on the price scale again and click
Scale Range: User Defined with Auto Set
Note that if you right click the price scale again, you will see a check mark next to
and not
However, if on the top menu bar you go to
Chart >> Scale
you will see check marks next to both
and
(I don't know the reason for this but it works so I'm not messing with it.)
