Date/Time: Sun, 18 Jan 2026 10:16:39 +0000
Current Price Line for Cum Delta Volume!
View Count: 598
| [2024-10-12 19:44:13] |
| J DIDDY - Posts: 142 |
HI support I want to add a 'Current Price Line' (or 'Current Scale line' to be precise) for a 1 Minute 'Cum Delta Volume Bars' chart, Scale: Auto zero centred. (No symbol candlesticks or price chart in the same region) It seems the 'current price line' only seems to work on the actual symbol 'price' NOT on the Cum Delta volume scale, which is where I need it so I have a better visual aid for when delta moves quick up and down the scale. Is there a way to do or hack this??? I need these scale settings above! Thx |
| [2024-10-14 15:15:28] |
| John - SC Support - Posts: 44021 |
We are not seeing any problem with using the "Current Price Line" study with the "Cumulative Delta Bars - Volume" study and having the "Cumulative Delta Bars - Volume" set to a scale of "Automatic Zero Centered". Make sure the following are set on the "Current Price Line" study: - Based On: "Cumulative Delta Bars - Volume" - Region: Same as "Cumulative Delta Bars -Volume" The default scaling of "Same as Region" for the "Current Price Line" should be fine, but if, for some reason, you are having an issue with this, change it to "Automatic Zero Centered". Refer to the following: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Chart Studies: Settings and Inputs Tab >> Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-10-22 10:24:51] |
Hi John I didn't realise I had to set the 'Based On' to Cum Delta... Many thanks!!! |
