Date/Time: Thu, 19 Nov 2026 12:57:17 +0000
Apex funded account activated as well as Rithmic data
View Count: 623
[2024-09-03 17:13:12]
User863230 - Posts: 1
Hi saw a thread that I need a Step 5 account to activate Apex funding Rithmic feed
Is this still necessary if I have Amp account ?
Thanks Clare
[2024-09-04 19:38:05]
You only need a live trading account if you will be getting your data from our Denali Exchange Data Feed. If you are getting your data from Rithmic, then this requirement does not apply.
An AMP account will suffice for verifying your non-professional status for the CME Group data, as Sierra Chart can connect to AMP.
For more information on this requirement, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you are wanting to get real-time data from our Denali Exchange Data Feed for the CME Group, then follow these instructions:
Also, to connect your Sierra Chart to Rithmic, follow these instructions:
Rithmic Trading Platform Service: Setup Instructions
Refer to the instructions at the following link to connect at least once a month to your AMP account:
Note that depending on what order routing service you are using with AMP will determine the instructions you need to connect. If you let us know, then we can point you to the proper instructions.
