Date/Time: Thu, 19 Nov 2026 13:27:32 +0000
Market Depth
View Count: 810
[2024-08-15 16:16:06]
Matt2514 - Posts: 7
Hello I am currently subscribed to Teton Data but only able to see 100 levels for the DOM. I am wanting to be able to show more depth of market and I have checked all that available online resources but can't seem to find out how to see more levels. Thanks
imageScreenshot 2024-08-15 080842.png / V - Attached On 2024-08-15 16:16:03 UTC - Size: 43.87 KB - 175 views
[2024-08-15 16:40:01]
Refer to the following:
File Menu: Not Receiving the Full Number of Market Depth Levels
[2024-08-15 16:43:27]
Matt2514 - Posts: 7
I have reviewed this page several times and all my settings are correct. Please advise thanks.
[2024-08-15 17:02:11]
What is the symbol for that chart?
[2024-08-15 17:03:51]
Matt2514 - Posts: 7
ES
[2024-08-15 17:13:23]
Select "File >> Market Depth Window".
Scroll to the bottom and then take an image of that window and attach it to this thread.
[2024-08-15 17:44:07]
Matt2514 - Posts: 7
Attached is the screen shot for the ES as well as the NQ both only showing 100 levels
imageScreenshot 2024-08-15 134216.png / V - Attached On 2024-08-15 17:42:31 UTC - Size: 228.39 KB - 256 views
imageScreenshot 2024-08-15 134320.png / V - Attached On 2024-08-15 17:43:51 UTC - Size: 224.42 KB - 241 views
[2024-08-15 18:38:25]
What this tells us is that you are being limited at the server and not within the software itself.
As such, select "Global Settings >> Sierra Chart Server Settings >> General" and set the option for "Max Depth Levels" to 0. Select OK to close that window and then select "File >> Reconnect". Refer to the following for this:
Sierra Chart Server Settings: Max Depth Levels (Global Settings >> Sierra Chart Server Settings >> General >> General)
[2024-08-15 18:43:53]
Matt2514 - Posts: 7
Thank you! That fixed it!
[2024-08-15 18:54:22]
We want to point out that this is covered at Step #4 in the documentation we pointed you to in Post #2.
[2024-08-15 18:58:00]
Matt2514 - Posts: 7
Thanks. No need to be a jerk about it.
