Date/Time: Thu, 15 Jan 2026 07:50:48 +0000
no current data after changing from Rithic to CGQ
View Count: 525
[2024-05-22 13:15:22]
User692627 - Posts: 4
Hallo Support Team,
Here is a short video in the drop box, I am explaining the problem.
https://www.dropbox.com/scl/fi/0f2zvzo8921ulpbr2ly0c/Anfage-Sierra-Chart-current-Data-22-05-_2024_15-03-21.mp4?rlkey=75yuw39770yt97qf6q50pk022&st=8mht8ai2&dl=0
Thanks for help!
Regards!
Bernd Hertfelder
[2024-05-22 14:55:40]
John - SC Support - Posts: 43987
Please follow the instructions at the following link to get the recent data to download:
If you are still having an issue after doing the above, then get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2024-05-23 12:35:03]
Thanks John,
I`ve solved the problem,
I inserted a sierra4.config file from a data backup 4 weeks ago, afterwards it worked.
Thanks for the answer and regards.
Bernd
