Date/Time: Sun, 19 May 2024 12:15:28 +0000
CL Continuous Volume Rollover
View Count: 990
[2014-08-18 14:03:04] |
Futures Operator - Posts: 239 |
For CL continuous chart volume based rollover, get the following error: Volume based rollover from CLQ4-NYMEX to CLU4-NYMEX occurs at 2014-07-18 | 2014-08-18 07:43:29 Unable to determine transition date based on volume from files: C:\SierraChart_NonCLR_LIVE\Data\CLU14.dly, C:\SierraChart_NonCLR_LIVE\Data\CLV14.dly | 2014-08-18 07:43:29 |
[2014-08-18 14:09:10] |
This error seems to have gone away after restarting SierraChart, not sure what was the cause.
[2014-08-18 16:42:13] |
If you still have the problem, what you need to do is select File >> Open Historical Chart and delete these two files: C:\SierraChart_NonCLR_LIVE\Data\CLU14.dly C:\SierraChart_NonCLR_LIVE\Data\CLV14.dly After that go to the chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
