Date/Time: Sun, 19 May 2024 02:17:50 +0000
Number bars highlight based on diagonal dominant side AskVol BidVol Percentage
View Count: 133
[2024-04-24 15:14:00] |
cherioJJ - Posts: 9 |
I have this issue where column #2 is selected to be highlighted by "Based on diagonal dominant side AskVol BidVol Percentage" But one of the Delta is showing -56, which is negative, but having a range up color. This seems to be inaccurate as it based on "Bid at previous price < Ask at next price percentage" Is there anyway to base it consistently on "Bid at price & Ask at next price percentage"? |
Screenshot (240).png / V - Attached On 2024-04-24 15:12:49 UTC - Size: 55.53 KB - 31 views Attachment Deleted. |
[2024-04-24 16:23:31] |
What is the Input for "Column 2 Numbers Bars Text" set to?
[2024-04-24 17:35:21] |
"Ask Vol Bid Vol Diff Diagonal one side"
Date Time Of Last Edit: 2024-04-24 17:39:55
[2024-04-24 22:53:47] |
You are not understanding what that number is. It is only showing you the Diagonal Difference for the Bid side. It is not showing you the Dominant Diagonal Difference. There is not a way to show just the Dominant Diagonal Difference, you would have to display the text as "Ask Vol Bid Vol Difference Diagonal" and then look at the numbers to see which is dominant, although the coloring can then give you that information. Refer to the following: Numbers Bars: Numbers Bars Text Types For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-25 13:38:59] |
Thanks for the clarification. Have selected Column #2 background coloring method to be "Based on Diagonal Dominant Side AskVol BidVol Percentage Currently the issue is with background highlighting. Sometimes it is based on "difference between ASK at next price and BID at price", which is what I want. But there are instances where they calculate based on "difference between ASK at price and BID at previous price" << which is causing the issue Is there a setting where it consistently base its highlighting of background color by whichever dominant side Ask at next price and Bid at price instead of sometimes calculating based on Ask at price and Bid at previous price? example: -If BID at price > ASK at next price, then range down color -If BID at price < ASK at next price, then range up color -At no point should it highlight based on difference between BID at previous price and ASK at price |
[2024-04-25 13:46:13] |
Please refer to screenshot. at the second price from the bottom it is -20, which is difference between BID at price and ASK at next price but highlighting of color is based on BID at previous price and ASK at next price <<< which is the issue I wish to resolve |
Screenshot (248).png / V - Attached On 2024-04-25 13:43:39 UTC - Size: 56.44 KB - 19 views |
[2024-04-25 15:09:40] |
Refer to the information at the following link that gives the precise definition of how the "Based on Diagonal Dominant Side AskVol BidVol Percentage" is calculated: "Numbers Bars: Background Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-25 16:33:43] |
As the settings: Background Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage calculates For the Bid: Bid Percentage = Bid Volume at Price / Ask Volume at Next Price. For the Ask: Ask Percentage = Ask Volume at Price / Bid Volume at Previous Price. Is there a setting where it consistently compares Bid at price and Ask at next price? |
[2024-04-25 17:41:02] |
The Text display option of "Ask Vol Bid Vol Diff Diagonal one side" does this. It only shows the Bid in comparison to the Next Ask. There is not a coloring option that does this.
[2024-04-25 17:56:16] |
Can i request this coloring option be implemented?
[2024-04-25 21:15:44] |
Yes, we have taken note. We just can't say when we can get to any request.
[2024-04-26 09:56:17] |
Thank you. Appreciate it
