Date/Time: Fri, 17 May 2024 22:21:09 +0000
Exporting data into excel
View Count: 88
[2024-04-19 03:17:10] |
Ghosttrader - Posts: 14 |
Hello, I'm wondering if you can advise on where to start if one wants to export volume profile data into excel. I want to be able to export the value area high, low and point of control values. This being for a specific time period for instance the first 30 minutes of trading. thank you. |
[2024-04-19 16:37:40] |
You would need to setup a Volume by Price study that is set for the specific time you want, and then use the Spreadsheet Study to get access to the particular data you want. Then export or copy the data from the Spreadsheet Study to Excel. Refer to the following: Volume By Price Study Using the Spreadsheet Study Working with Spreadsheets: Different Methods to Get Data Into and Out of Spreadsheets For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
