Date/Time: Sat, 18 May 2024 14:45:17 +0000
problem.Number Bars Calculated vAl. study BASED ON ANOTHER chart
View Count: 85
[2024-04-18 15:51:19] |
User335019 - Posts: 3 |
Hello there, I want Num.Bars.Calc.Val study to reference (calculate using different "volume filtered" chart) to another charts' data. The help states it is possible. "...Follow the instructions below to add a Numbers Bars Calculated Values study that references another chart...." And help continues "... 8. Set the "Reference Other Intraday Chart" Input to Yes..." But i can not find this "Referenca Other Intraday Chart" input, so i can not make it yes.. My question Where exactly is this input, so that i make it "yes". Thank you for your attention. PS Can "study/price overlay" be used to make this happen ? |
[2024-04-18 15:54:10] |
The Input for "Reference Other Intraday Chart" is located on the Numbers Bars Calculated Values studies settings. It is the 10th entry from the top of the list. The instructions are correct, you need to set this to "Yes" and then give the chart number in the item below it. You can not use the Study/Price Overlay to do this. You have to use the method described in the documentation that you are referencing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
