Date/Time: Sat, 18 May 2024 22:03:34 +0000
multiple order allocation
View Count: 80
[2024-04-18 15:47:07] |
userfifty3 - Posts: 7 |
Hi, I created an order allocation for multiple accounts. It works but it does not save the configuration that i set. I also choosed under order allocation to trade accounts > Available Accounts (List) an account but after i click the button apply all and then ok it changed instead another account in my available accounts (list). How can i save it? To not constantly change it everytime. |
[2024-04-18 15:49:55] |
What you are describing should not be occurring. Make sure you are selecting the account you want to add at the top of the page in the entry for "Available Accounts" and then select the "Add" button just below it to add that account to the list of accounts to copy the trades to. Refer to the instructions at the following link: Order Allocation to Trade Accounts: Setup Instructions Once you have setup the "Order Allocation to Trade Accounts" it will keep that setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
