Date/Time: Thu, 10 Jul 2025 02:52:10 +0000
Second instance
View Count: 327
[2024-04-18 03:27:27]
User336233 - Posts: 3
Hello, I'm currently managing two different trading accounts, so I set up a new installation to have a completely separate instance and be able to connect to two brokers simultaneously. However, I'm struggling to figure out how to share my Denali feed data. I've looked at the following links: "https://www.sierrachart.com/index.php?page=doc/NewInstance.php#InstructionsForSharingDataUsingSubInstances" and "https://www.sierrachart.com/index.php?page=doc/MultipleServices.html", but the instructions provided aren't very clear. Could you please assist me?
[2024-04-18 14:19:51]
John - SC Support - Posts: 40812
If the installations are on the same computer, then there is nothing special you need to do. Just make sure the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" is set to "Yes" in both installations (which it should be by default).
If the installations are on different computers, then you would need to pay a second set of exchange fees to allow the data to the two different systems. Refer to the following:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
