Date/Time: Sat, 18 May 2024 22:26:48 +0000
Daily PNL wrong
View Count: 119
[2024-04-15 14:58:05] |
User985161 - Posts: 4 |
I have multiple accounts through Rithmic and on 1 account my daily PNL is displaying a negative # that is way off when the account is actually positive. I have only noticed this with 1 account so far.
[2024-04-15 17:30:26] |
Refer to the following: Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-16 19:38:36] |
I tried all these methods to reset and recalculate the Daily PNL and as soon as I put on the 1st trade of the day it comes out with a calculated # that is way off from what it actually could be. I also updated to the newwst version of sofatware to correct the issue but it still is there.
[2024-04-16 20:32:20] |
Make sure you have gone through and set the "Chart >> Chart Settings >> Trading >> Order Fills Start Date-Time" to a time where you are flat in the market, or better yet, to just before you start trading for the day. This will ensure that the order fills from that time forward are aligned. If you open a trade and have a Daily Profit/Loss showing after doing the above, then let us know. Please review the information at the following link: Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-17 15:16:28] |
I set the "Order Fills Start Date-Time" took 1 test trade was positive 1 point in the ES, closed the position and the calculated PNL on the trading DOM is showing -13.25
[2024-04-17 21:52:31] |
Sierra_Chart Engineering - Posts: 14423 |
We do not understand the point you are trying to make with post #5. We do not know what is right or wrong. Or what that value represents. And we do not know how you have set the Order Fills Start Date-Time settings. Here is all of the relevant information: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-18 17:38:21
