Date/Time: Sun, 19 May 2024 22:10:51 +0000
Trade from Sierra with Rithmic / Apex
View Count: 196
[2024-04-06 14:32:31] |
Rnn - Posts: 49 |
Hi, Is it possible to trade from Sierra with Apex/Rithmic while using denali data and not Apex/Rithmic data like u recommended on ur post so I could have the option to see the trade / orders on chart? Is there a way that I can simultaneously send orders via Rithmic / Sierra? |
[2024-04-08 14:50:10] |
John - SC Support - Posts: 31733 |
Yes this is supported. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-15 13:59:32] |
Tomas Herka - Posts: 5 |
Hello SC, I have an issue with conecting into Apex /Rithmic. I have correct username and password from Rithmic but wehenever I try to connect to Sierra chart there is pop of error. I gave my username and password to my friend to try and he has no issue to connect his Sierra chart. Any idea where could be possible problem? Thank you very much. |
Attachment Deleted. |
[2024-04-15 17:10:34] |
Refer to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
