Date/Time: Sun, 19 May 2024 13:39:04 +0000
Fehlermeldung
View Count: 122
[2024-03-30 17:33:03] |
User437588 - Posts: 56 |
Hallo Ich möchte in einem bestehenden Chartbook einen neunen Tageschart mit NQ Daten erstellen und bekomme folgende Meldung. You Have perfomed an operation which cannot be completed because thsi chart is being referenced by studies other charts in the Chartbook. Do you want to clear those references? Ich kann damit nichts anfangen SC erstellt immer den 60 Minuten Chart, anstatt wie gewünscht den Daily Chart. Wo liegt das Problem? |
[2024-04-01 13:46:35] |
John - SC Support - Posts: 31708 |
From Google Translate: Hello, I want to create a new daily chart with NQ data in an existing chartbook and I get the following message.
You have performed an operation which cannot be completed because this chart is being referenced by studies other charts in the chartbook. Do you want to clear those references? I can't do anything with it SC always creates the 60 minute chart instead of the daily chart as requested. Where is the problem? Refer to the following: Unable to Change the Bar Time Period for Charts It sounds like you are trying to change an existing chart or are duplicating a chart. If you select "File >> Find Symbol" and open an historical chart then you will not have this issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
