Date/Time: Mon, 14 Jul 2025 20:56:22 +0000
How to use the Scroll Wheel for Interactive Scaling?
View Count: 1292
[2024-03-24 11:26:56]
MarkusK - Posts: 106
Hi, it's probably a trivial question, but I couldn't find an answer yet:
In the documentation for the "Interactive Scaling" it says: "The Scroll Wheel of your system can also be used for Interactive Scaling."
If I understand this correctly, I can use the scroll wheel of my mouse to expand/compress the vertical axis, right?
But how exactly can I do this?
I already know that I can expand/compress the horizontal (time) axis (i.e. changing the bar spacing) by holding down the Shift key and using the mouse wheel.
I also know that i can expand/compress the vertical (price) axis by holding down the CTRL key and left click + move the mouse.
But how exactly can I expand/compress the vertical (price) axis with the scroll wheel of my mouse?
[2024-03-24 18:42:33]
John - SC Support - Posts: 40889
Refer to the following setting that controls what the scroll wheel does:
General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll)
[2024-03-24 19:21:24]
Thanks for your quick reply John!
I already read that section (and also tried all 7 available settings) but there doesn't seem to be any option to adjust the interactive scaling of the vertical (price) axis with the mouse wheel.
It seems that I can only use the mouse wheel to scroll the vertical axis, but not expand/compress it.
Is it correct that the scaling (expanding/compressing the axis) via the mouse wheel only works for the horizontal (but not the vertical) axis? Or am I missing something?
[2024-03-24 20:06:30]
Sierra_Chart Engineering - Posts: 20198
We looked into this. In this particular case, the Scroll Wheel only moves the vertical scale up and down. It does not perform an expand or compress (Interactive Scale Range).
We will update the documentation regarding this.
[2024-03-25 06:04:59]
Thanks for clarification!
[2024-06-15 23:39:41]
User912620 - Posts: 12
hi there, can there be an option or shortcut (maybe by holding ALT?) to adjust the veritable price expansion/compression/
[2024-10-15 02:16:29]
Bedhog - Posts: 182
I just picked up an HP430 Wireless Keypad and want to assign buttons for Interactive Scale Range +- for the active chart window. I found an option for decrease bar width and increase bar width, but not increase bar height or decrease bar height. Is that a thing that can be assigned?
Date Time Of Last Edit: 2024-10-15 02:19:48
[2024-10-15 14:30:15]
There are no Keyboard Shortcuts for changing the vertical scale range.
[2025-01-01 12:20:19]
C.Lux - Posts: 1
Greetings,
is it possible to find a Solution for not being able to hotkey the scrool wheel & change the vertical scaling with the scroll wheel or a hotkeyed button?
Happy new Year
[2025-05-25 15:10:14]
rodicaaqirossa111 - Posts: 1
Hi, I'm also interested in this option , so far I've managed to use the scroll wheel to change the spacing horizontally , but no way to change the spacing vertically too , so how or when will this be possible ?
Thanks.
[2025-05-28 02:26:27]
Do you want to use the scroll wheel to perform Interactive Scale Range operations:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
