Date/Time: Sun, 12 May 2024 22:35:16 +0000
Symbol format when issued
View Count: 124
[2024-03-20 15:10:37] |
User472677 - Posts: 316 |
Using sc data what needs to added for 'when issued' to a stock symbol? In case sc feed does not work, using Interactive Brokers data what needs to be added for 'when issued' to a stock symbol? GEVwi GEV wi GEV-wi |
[2024-03-20 22:31:48] |
Sierra_Chart Engineering - Posts: 14324 |
We are not familiar with this. We do not see how we can help with this. In the case, of the Sierra Chart Denali Data Feed you can search for US equities symbols: File Menu: Searching for Symbols We cannot help at all with Interactive Brokers symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-20 23:10:37
[2024-03-22 17:19:53] |
Hi, It is not showing up on search. You should be able to find out from your data vendor, format for 'when issued'. From there you would know how sc is formatting it and then give me the answer. |
[2024-03-22 17:52:33] |
[2024-03-24 00:49:57] |
There is no data vendor. We do not work with a data vendor for the US Equities Data. This data comes from UTP and CTA. You can go to them with your question. We do not know what you are referring to and we will not be responding further. The only thing that we would say is whatever it is you want, we do not have it and we have no idea what it is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-24 00:51:15
