Date/Time: Tue, 14 May 2024 21:09:59 +0000
Clarification regarding sierra package
View Count: 165
[2024-03-15 15:33:33] |
Dhanush - Posts: 19 |
Hi, Good day to you. I am confused a little regarding the packages and henceforth the email. I usually opt for package number 12, integrated advance MBO. When I had it, I wasn't able to access US equities. I thought I would have delayed equity data but it didn't. I am guessing I have read it wrong. Can I kindly know when I opt for package 12, what else do I need to buy to get equities data? I want to use equities data for practising day trading. Kindly let me know. I understand all the instructions will be given somewhere in SC support but I am still confused a little. |
[2024-03-15 19:13:00] |
John - SC Support - Posts: 31611 |
Are you wanting real-time U.S. Equities or will Delayed Streaming Data that is 15 minutes behind the real-time data work for you?
[2024-03-25 07:28:41] |
Hi, I am looking for real time data so I can paper trade as well. (Sorry, I thought I had sent the reply but I didn’t apparently) Thank you |
[2024-03-25 13:51:01] |
To get the real-time data, you need to be on one of the "Integrated" packages (Package 12 gives you the additional MBO information). Refer to the packages at the following link: Description of Service Packages and Pricing: Integrated Packages And then you would need to go through the Setup Instructions for the exchange you want at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Note that we have two U.S. Equities exchange options: - NASDAQ TotalView: Has the data for the trading that is done on the NASDAQ only, but does include the Market Depth data. - U.S. Equities Consolidated Tape: Has the data for the trading that is done for all U.S. exchanges for an instrument, but does not have any market depth data. It is also possible to combine these two by activating both and using a symbol with an _MBO (such as IBM_MBO), which will give you the consolidated price and volume along with the market depth from the NASDAQ TotalView. Refer to the following and the section below it, regarding these options: Denali Exchange Data Feed: US Equities Consolidated Tape Data Feed Notes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
