Date/Time: Thu, 16 May 2024 04:07:49 +0000
Pivot Points
View Count: 142
[2024-03-09 16:31:29] |
User575399 - Posts: 305 |
Hello, I would like to overlay my SPY pivot points onto my ES chart. Is this possible since they have different price grids?
[2024-03-10 16:02:59] |
Anyone?
[2024-03-11 16:56:58] |
John - SC Support - Posts: 31666 |
To start, you use the "Study/Price Overlay" to overlay the Pivot Points from one chart to another. Refer to the following: Study/Price Overlay Study Then, you would want to set the "Study/Price Overlay" scale to "Independent" in order to have it show in the main chart, since the charts have very difference price levels. Refer to the following: Chart Scale and Scale Adjusting: Independent (Scale Range) If you are wanting the Pivot Points to end up relative to some particular point in the ES chart, then you would need to also use the "Spreadsheet Study" and adjust the Pivot Points data as you want relative to the ES data. Refer to the following: Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
