Date/Time: Thu, 16 May 2024 04:30:41 +0000
[Programming Help] - Chart Calculator Properties > Config window
View Count: 137
[2024-03-09 00:12:04] |
User14953 - Posts: 193 |
How to assign text from the Tool Config list to fields in the Chart Calculator Properties > Config window? |
sc tool config.png / V - Attached On 2024-03-09 00:11:30 UTC - Size: 27.77 KB - 38 views |
[2024-03-11 15:47:07] |
John - SC Support - Posts: 31666 |
In the image you provided, you enter the text in the "Tool Configuration Name" field that is just below the selection you have open. Then save the particular configuration. Refer to the following: Chart Drawing Tools: Using Multiple Drawing Tool Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
