Date/Time: Fri, 03 May 2024 13:18:48 +0000
UPDATING IMPOSSIBLE
View Count: 912
[2014-08-06 13:30:05] |
User45578 - Posts: 49 |
I CNT GET 1168 version ERROR MESSAGE/window error code:12030 LOOK IN ATTACHED PLEASE
[2014-08-06 16:43:46] |
A firewall on your system or network is blocking the connection to the Sierra Chart server. For HTTP communication errors, refer to the Login Problems section here: Sierra Chart - Software Login Instructions: Login Problems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
