Date/Time: Thu, 05 Nov 2026 17:44:38 +0000
Adding Indicators
View Count: 834
| [2024-02-04 17:09:03] |
| User83524 - Posts: 49 |
Using the same chart, how do I add three indicators together and create a fourth indicator? What's the easiest way? Thanks!
| [2024-02-05 17:21:00] |
| John - SC Support - Posts: 48447 |
To add 3 studies together, you could use the "Study Subgraphs Add", "Spreadsheet Study", or the "Spreadsheet Formula" For the "Study Subgraphs Add" you would need to use two copies, one to add the first two studies, then a second to add the result of the first "Study Subgraphs Add" to the third study. Refer to the following: Using the Basic Arithmetic Studies With the "Spreadsheet Study", you would need to have the 3 studies on the same chart and then their data will be in the columns after the calculation columns, then you would just add them together. You can just reference the cells, such as "AA3 + AB3 + AC3", but it is best to use the study/subgraph nomenclature as "ID1.SG1@3 + ID2.SG1@3 + ID3.SG1@3". Refer to the following: Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study Despite it's name, the "Spreadsheet Formula" uses the Alert syntax, so you would enter a formula for this like the following: =ID1.SG1 + ID2.SG1 + ID3.SG1 Refer to the following: Spreadsheet Formula Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-02-05 18:08:24] |
John . . Thanks for the detailed answer. Much appreciated!
