Date/Time: Tue, 14 Jul 2026 04:07:40 +0000
Study Support
View Count: 764
| [2024-01-10 15:34:57] |
| User920222 - Posts: 13 |
Does Sierra Chart provide support/access to study $NSHF? I'm able to open the chart but it doesn't have data. I have service package 5.
Date Time Of Last Edit: 2024-01-10 16:08:11
| [2024-01-10 17:36:57] |
| John - SC Support - Posts: 47164 |
We are not able to find any information on this symbol. What is it and where does it come from?
| [2024-01-10 18:06:38] |
$NSHF is advancing NYSE issues minus declining NYSE issues, or net advancing issues. I learned about the study on the support board just recently. I went to Find Symbol on the platform, typed in $NSHF and found the study. It works on Replay Chart but not live. I would like to have access to the live chart, if possible.
| [2024-01-11 15:18:37] |
This would be available through the Market Statistics as the NISS. For the NYSE, the symbol is NISS-NYSE. Refer to the information here: Sierra Chart Market Statistics For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-01-19 18:53:00] |
I bought a new computer, installed Sierra platform and now I cannot see account balance. Broker suggested I should contact Sierra directly. Please advice.
| [2024-01-19 21:59:07] |
Please select "Global Settings >> Data/Trade Service Settings >> Main Settings" and tell us what the entry for "Current Selected Service" is set to.
| [2024-01-23 00:28:38] |
SC Data- All Services
| [2024-01-23 01:23:04] |
| Sierra_Chart Engineering - Posts: 24255 |
Who is your broker? We need to know what trading platform service they set you up on.
| [2024-01-26 19:11:47] |
AMP Futures
| [2024-01-26 21:38:08] |
AMP will have you setup to use either Teton or CQG for your order routing. We need to know which one of these you are setup with.
| [2024-01-26 22:21:36] |
CQG
| [2024-01-29 15:17:24] |
Follow the instructions at the following link to connect to your CQG account: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
