Date/Time: Fri, 18 Jul 2025 23:03:25 +0000
Price not correct after rollover
View Count: 528
[2023-09-18 10:31:10]
User716124 - Posts: 2
Hi
I have a problem that when I rollover the historic price changes. Please see attachments to see that the everything shifts after a rollover. This is not confined to CL.
imageCLU23.png / V - Attached On 2023-09-18 10:25:16 UTC - Size: 389.35 KB - 108 views
imageCLV23.png / V - Attached On 2023-09-18 10:25:26 UTC - Size: 379.51 KB - 103 views
imageCLZ23.png / V - Attached On 2023-09-18 10:25:33 UTC - Size: 381.29 KB - 99 views
[2023-09-18 17:06:42]
John - SC Support - Posts: 40963
You are using a Back-Adjusted Continuous Contract. As such, the previous contracts are adjusted up/down in order to match to the current contract. If you do not want this, then do not use a Back-Adjusted option. Refer to the following:
Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options
[2023-09-19 06:50:38]
Thanks very much for the answer.
