Date/Time: Thu, 16 May 2024 00:14:40 +0000
SC Data Feed - connection error
View Count: 1732
[2014-07-14 13:14:08] |
User14266 - Posts: 225 |
Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2014-07-14 08:11:23 Socket has been shutdown and closed. | 2014-07-14 08:11:23 SC Exchange Data: Disconnected from the server. | 2014-07-14 08:11:23 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-07-14 08:11:23 Using username 0 | 2014-07-14 08:11:25 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-07-14 08:11:25 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-07-14 08:11:25 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2014-07-14 08:11:46 Socket has been shutdown and closed. | 2014-07-14 08:11:46 SC Exchange Data: Disconnected from the server. | 2014-07-14 08:11:46 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-07-14 08:11:46 Using username 0 | 2014-07-14 08:11:48 SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-07-14 08:11:48 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-07-14 08:11:48 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2014-07-14 08:12:09 Socket has been shutdown and closed. | 2014-07-14 08:12:09 SC Exchange Data: Disconnected from the server. | 2014-07-14 08:12:09 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-07-14 08:12:09 Using username 0 | 2014-07-14 08:12:11 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-07-14 08:12:11 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-07-14 08:12:11 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2014-07-14 08:12:32 Socket has been shutdown and closed. | 2014-07-14 08:12:32 SC Exchange Data: Disconnected from the server. | 2014-07-14 08:12:32 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-07-14 08:12:32 Using username 0 | 2014-07-14 08:12:34 SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-07-14 08:12:34 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-07-14 08:12:34 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2014-07-14 08:12:55 Socket has been shutdown and closed. | 2014-07-14 08:12:55 SC Exchange Data: Disconnected from the server. | 2014-07-14 08:12:55 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-07-14 08:12:55 Using username 0 | 2014-07-14 08:12:57 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-07-14 08:12:57 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-07-14 08:12:57 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2014-07-14 08:13:18 Socket has been shutdown and closed. | 2014-07-14 08:13:18 SC Exchange Data: Disconnected from the server. | 2014-07-14 08:13:18 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-07-14 08:13:18 Using username 0 | 2014-07-14 08:13:20 SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-07-14 08:13:20 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-07-14 08:13:20 |
[2014-07-14 13:16:36] |
The data feed has been restored. This is the discussion thread: NOTICE: Sierra Chart Exchange Data Feed Was Down Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-14 13:20:21] |
moonmist - Posts: 127 |
Hi, There seems to be some connection problems with Sierra Chart Real-Time Feed on and off for the past half an hour: SC Exchange Data: There has been no activity on the network socket. Will reconnect. | 2014-07-14 09:16:32 Socket (2188) - Shutdown and closed. | 2014-07-14 09:16:32 SC Exchange Data: Disconnected from the server. | 2014-07-14 09:16:32 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-07-14 09:16:32 Using username 0 | 2014-07-14 09:16:34 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-07-14 09:16:34 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-07-14 09:16:34 Socket (1064) - Connected. | 2014-07-14 09:16:34 Date Time Of Last Edit: 2014-07-14 13:22:16
[2014-07-14 13:35:30] |
Yes we are aware of this. It is intermittent. Please refer to this post here: NOTICE: Sierra Chart Exchange Data Feed Was Down Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
