Date/Time: Mon, 14 Jul 2025 21:09:42 +0000
Unable to pan the chart
View Count: 456
[2023-08-20 05:43:40] |
pennydoll9 - Posts: 20 |
I am unable to pan the chart with the mouse left click button? I have set the value "yes" but still cannot move/pan the chart. Chart Drawing Tools: Support Vertical Scaling/Movement With Hand Tool (Global Settings >> Tool Settings >> General >> Tool Options) |
[2023-08-21 02:29:25] |
ivory - Posts: 95 |
Have you selected the hand tool? Alt + H. You can also configure SC to default to the hand tool.
[2023-08-21 02:49:31] |
Sierra_Chart Engineering - Posts: 20198 |
Use the Hand Tool: Chart Drawing Tools: Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
