Date/Time: Thu, 03 Jul 2025 23:51:30 +0000
Some numbers inside footprint chart are cut off on either side, doesn't fit
View Count: 414
[2023-08-18 22:07:29]
Theyoungnoble - Posts: 1
I have a candle body outline on each footprint, the numbers aren't scaling correctly and some on either side are cut off, all three digit and some two digit numbers have one mising
[2023-08-21 14:22:26]
John - SC Support - Posts: 40745
Refer to the following regarding scaling the Numbers Bars:
Numbers Bars: Scaling a Numbers Bars Chart
If that does not help you, then we would need to see an image of what you are seeing.
