Date/Time: Tue, 30 Apr 2024 05:06:06 +0000
help! lol
View Count: 274
[2023-06-02 21:24:44] |
User424220 - Posts: 9 |
all I want to do is move the ask volume and bid volume study label from the left side to the right side of the chart. Can't figure it out. Appreciate some help. Thanks I've spent hours trying to figure it out. Unfortunately, your terminology and search doesn't make finding the answers easy. |
[2023-06-02 21:44:27] |
John - SC Support - Posts: 31189 |
We need more information - in particular, what study are you using and what information are you trying to move. A screenshot would be helpful as well. Refer to the following for how to take a screenshot for our purposes: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-02 23:44:34] |
https://www.sierrachart.com/image.php?Image=1685749259885.png
SierraChart_64_NCQz2GwT0X.png / V - Attached On 2023-06-02 23:23:24 UTC - Size: 57.27 KB - 61 views |
[2023-06-05 13:52:07] |
The text you are wanting to move is part of the Region Header and it can not be moved. It is always located with the left-alignment like it is. The color of the "Bid" and "Ask" in that line is determined by the color of the Subgraph that it is representing. You will see that the "Ask" is green and so are the bars, and the "Bid" is grey and so are the bars. Refer to the following for changing the color: Chart Studies: Subgraphs Tab >> Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
