Date/Time: Sun, 01 Oct 2023 21:41:54 +0000
Spreadsheet function visualisation
View Count: 116
[2023-05-26 03:29:33] |
Macan93 - Posts: 3 |
Hi I have a spreadsheet function that I would like to visualize with values in a grid in the same way as "Number Bars calculated values". How do I do that? |
[2023-05-26 14:03:02] |
John - SC Support - Posts: 26610 |
The Numbers Bars Calculated Values grid is only available if you create a custom study. Refer to the following: ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type If you want to have the numbers in a line, like the Numbers Bars Calculated Values, but without the grid lines, then set the study to be in its own region, and then set the Subgraph Draw Style to "Value of Subgraph". You will also want to set the "Width/Size" to something that you can read - typically 8-10. In order to get the values into a single line, you need to expand the range of the scale to compress the data into a single line. For more information on the items mentioned above, refer to the following: Chart Studies: Settings and Inputs Tab >> Chart Region Chart Studies: Value of Subgraph (ACSIL: DRAWSTYLE_VALUE_OF_SUBGRAPH) Chart Studies: Subgraphs Tab >> Line Width Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
