Date/Time: Thu, 02 May 2024 18:55:46 +0000
Data connection
View Count: 620
[2024-02-01 19:05:18] |
User882391 - Posts: 82 |
No the DPL is being calculated wrong it should be showing -.75 instead of 4.50P not sure why is there trade thats not being closed? so the screenshot is showing the trade executed and DPL is calculated based on trade not being seen. Date Time Of Last Edit: 2024-02-01 19:15:28
Trade Pending.png / V - Attached On 2024-02-01 19:15:23 UTC - Size: 82.08 KB - 21 views |
[2024-02-01 19:51:08] |
John - SC Support - Posts: 31328 |
The information at the link we sent you to goes through all of the possible situations. You need to work through the items on that page to find what is contributing to your Daily P/L.
[2024-02-01 19:55:01] |
It doesnt add up since there's no trade open
[2024-02-01 20:25:12] |
same thing again there's a pending trade locked in from 4874 on ESH4 product for some reason I cant understand. please advise how to clear invisible pending trade
[2024-02-01 21:44:07] |
Is it a Pending trade, as it working but not open? Or is it an Open trade? Also, are you in simulated or live mode? If this is an old trade that did not close, then this means that the system did not receive the fill for closing the position. You would need to manually enter the closing fill to offset it properly. Refer to the following: Trade Activity Log: Manually Inserting Missing Order Fills Also refer to the following to help find what is missing: Trade Activity Log: Solving Inaccurate Trade Statistics for Charts Field Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-01 22:43:21] |
I can’t tell I’m guessing it’s from the Sierra glitch that happened yesterday and not sure how to investigate it at this point.perhaps easier to speak over the phone
[2024-02-01 22:51:19] |
Please set your "Trade Activity Log" to display all the data that would include this "phantom" trade. Then make sure you are on the "Trade Activity" tab and select "File >> Save Log As" and then save the log and then attach it to this thread for us to look through it. You can attach the log privately. Refer to the following for how to attach a file: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-02 02:54:57] |
Sierra_Chart Engineering - Posts: 14182 |
If you are referring to an incorrectly reported Trade Position, then refer to: Trading Information Windows: Incorrectly Reported Trade Position Quantity Editing the fills will have no effect upon this. If you are referring to an order, then refresh the orders list: Trade Menu: Refresh Trade Data From Service (Trade menu) Editing/inserting order fills is not going to have any effect upon this. Editing the order fills might be useful to correct an incorrect Daily Profit/Loss or a problem with the display of order fills on the chart. Otherwise, it is not going to make any difference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-02 03:01:28
