Date/Time: Thu, 02 May 2024 11:17:08 +0000
[Programming Help] - Errors rebuilding older indicator in v2363
View Count: 248
[2023-05-19 14:09:15] |
jivetrader - Posts: 383 |
-- Starting remote build of Custom Studies Source files: newZZb2.cpp. 64-bit -- 14:08:13 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: newZZb2.cpp: In function 'void scsf_newZZb2(SCStudyInterfaceRef)': newZZb2.cpp:270:37: error: 'struct s_sc' has no member named 'PersistVars' 270 | int &LabelCount = sc.PersistVars->Integers[1]; | ^~~~~~~~~~~ newZZb2.cpp:271:37: error: 'struct s_sc' has no member named 'PersistVars' 271 | int &PriorLastZZEndpointIndex = sc.PersistVars->Integers[2]; | ^~~~~~~~~~~ newZZb2.cpp:272:37: error: 'struct s_sc' has no member named 'PersistVars' 272 | int &ZigZagStartIndex = sc.PersistVars->Integers[3]; | ^~~~~~~~~~~ newZZb2.cpp:326:105: error: 'DAYS' was not declared in this scope 326 | NextSessionStart = sc.GetTradingDayStartDateTimeOfBar(sc.BaseDateTimeIn[sc.UpdateStartIndex - 1]) + 1*DAYS; | ^~~~ newZZb2.cpp:347:78: error: 'DAYS' was not declared in this scope 347 | NextSessionStart = sc.GetTradingDayStartDateTimeOfBar(IndexDateTime) + 1*DAYS; | ^~~~ newZZb2.cpp:616:59: error: cannot convert 'SCDateTime' to 'double' in assignment 616 | ZigZagTimeSpan = sc.BaseDateTimeIn[ZigZagIndex+1] - sc.BaseDateTimeIn[BackRefIndex]; newZZb2.cpp:618:53: error: cannot convert 'SCDateTime' to 'double' in assignment 618 | ZigZagTimeSpan = sc.LatestDateTimeForLastBar - sc.BaseDateTimeIn[BackRefIndex]; newZZb2.cpp:622:56: error: cannot convert 'SCDateTime' to 'double' in assignment 622 | ZigZagTimeSpan = sc.BaseDateTimeIn[ZigZagIndex] - sc.BaseDateTimeIn[BackRefIndex]; -- End of Build -- 14:08:17 |
newZZb2.cpp - Attached On 2023-05-19 14:09:00 UTC - Size: 23.74 KB - 70 views |
[2023-06-02 03:39:00] |
Hi, is there a resource where I can find out more information on this error?
[2023-06-02 07:37:36] |
User431178 - Posts: 412 |
error: 'struct s_sc' has no member named 'PersistVars' Instead of above use the functions listed at the link below. Persistent Variable Functions error: 'DAYS' was not declared in this scope Need to use SCDateTime member function for this Working with the SCDateTime Variables and Values: DAYS() error: cannot convert 'SCDateTime' to 'double' in assignment Need to use SCDateTime member function to get datetime as double Working with the SCDateTime Variables and Values: GetAsDouble() or look at an alternative way of determining and displaying the time span. Date Time Of Last Edit: 2023-06-02 07:37:56
newZZb2.cpp - Attached On 2023-06-02 07:37:33 UTC - Size: 24.17 KB - 86 views |
