Date/Time: Fri, 03 May 2024 23:51:49 +0000
NQ Daily Historical Data
View Count: 329
[2023-05-18 23:59:24] |
Delta Tango Foxtrot - Posts: 32 |
I'm seeing a discrepancy in historical pricing. When viewing August 22, 2022 on my chart the NQ Mini shows a high of 13,555.5. However when viewing the same day in Tradingview and Barchart I see a high of 13,226.5. I've tried deleting and downloading the data, but it shows the same. Days around that Aug 22, 2022 date are also wrong. Any thoughts on why and how to correct? |
[2023-05-19 05:10:18] |
Sierra_Chart Engineering - Posts: 14207 |
Provide an image of the chart or Trade DOM showing this, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-20 01:42:01] |
Here's an image showing the bar with price and date. https://www.sierrachart.com/image.php?Image=1684546706904.png |
[2023-05-20 16:01:18] |
Also see this image showing that on the same chart the most recent candle shows an accurate price. https://www.sierrachart.com/image.php?Image=1684598336629.png |
[2023-05-20 16:01:21] |
You are looking at a continuous back adjusted chart. You need to choose a rollover option that is not back adjusted: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-20 16:01:34
[2023-05-20 16:24:09] |
Okay. Changed to "Continuous Futures Contract - Date Rule Rollover" and that did fix the issue. Thank you for the assistance, however I'm wondering if the backward adjustment options result in incorrect data, what is the purpose? |
[2023-05-22 14:25:39] |
John - SC Support - Posts: 31362 |
The purpose is to bring the previous contracts "in line" with the current contract. It all just depends on how you want to look at the historical data. If you want to view it as if it were a single contract, then you would want to back-adjust. If you want to view the individual contracts as they were, then do not.
