Date/Time: Mon, 06 May 2024 23:09:17 +0000
Denali data with AMP order routing
View Count: 250
[2023-05-18 17:02:22] |
User192201 - Posts: 19 |
Hi, I would like to use AMP order routing/execution but Denali data - Is there a way to do it - thank you
[2023-05-18 18:13:54] |
Sierra_Chart Engineering - Posts: 14244 |
Yes. Use Teton order routing: Sierra Chart Teton Futures Order Routing And refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
