Date/Time: Sat, 27 Apr 2024 19:42:21 +0000
Market Depth Historical Graph Study not working
View Count: 437
[2023-05-17 02:16:03] |
phased - Posts: 8 |
I am having problems with my market depth historical graph study not displaying on my chart. Is it because I'm on package 10 but I'm Evaluating Package 12 until 2023-06-13, 26 days? I have completed the Downloading Of Historical Market Depth Data 11 steps. And the first 6 steps in Market Depth Historical Graph Not Displaying because I don't want to lose my settings to default. |
[2023-05-17 13:43:23] |
Actually, you are on package 11 and are evaluating Package 12 until June 13. So in either case, you have the ability to use the Market Depth Historical Graph. Additionally, you do have data that has the Market Depth. Please give us a screenshot of what you are seeing and let us know what exactly the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-17 14:25:01] |
phased - Posts: 8 |
This is what I'm seeing and my settings https://i.imgur.com/ipj2yFT.png https://i.imgur.com/ZJGQUdI.png I am trying to get it to look something like this https://i.imgur.com/Ul4oYBc.png |
[2023-05-17 15:55:08] |
It is something with the particular setting you have. Please get us that chart so we can take a look. Follow these instructions to get us the chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-18 00:28:19] |
phased - Posts: 8 |
I opened Sierra Chart today and the market depth historical graph all of a sudden started working. Thank you!
[2023-05-22 17:40:39] |
phased - Posts: 8 |
Sorry but it stopped working. Here is my chart.
Private File |
[2023-05-22 23:16:23] |
The main issue you have is that you have hardcoded values for the "Highest Quantity for Coloring" and for the "Lowest Quantity for Coloring". These are set to 600 and 250 (respectively), so anytime the values in the region are not within this range, the study will not show anything. You should use a "Percent of Maximum Depth" and then also consider using one of the other options for the "Determine Min and Max Levels From". Refer to the information for these Inputs on the following link: Market Depth Historical Graph: Study Inputs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
