Date/Time: Thu, 03 Jul 2025 04:27:02 +0000
Horizontal Scroll as Price Moves
View Count: 384
[2023-05-09 14:38:23] |
thebridgetender - Posts: 1 |
Hello, Is there a way to add padding horizontally so that the last bar printed stays X amount of distance away from the right side of the screen? I am using a Study that shows the amount of orders on the books on the right edge by the current price range. The candles will continue to run into the side of the screen, therefore covering the information. Thanks |
[2023-05-09 16:19:49] |
John - SC Support - Posts: 40722 |
Refer to the following: Working With Charts: Right Side Fill Space For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
