Date/Time: Mon, 14 Jul 2025 20:34:36 +0000
cannot see data when i connect to cqg webapi
View Count: 438
[2023-05-02 14:23:50] |
User144295 - Posts: 74 |
Hi Team, I cannot see data when i connect to cqg webapi. I just purchased sierra data yesterday. I contacted AMP and they advised it is issue on sierra site. Thanks for help. |
Private File |
[2023-05-02 17:13:02] |
John - SC Support - Posts: 40889 |
We do not support data from CQG for the CME Group and EUREX. Therefore, you will have to get this data from our Denali Exchange Data Feed. Follow the instructions at the following link to setup the data for the CME Group: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-01 21:49:09] |
Hello Sierra team, I had small pause from trading and now considering to restart my data feed. The same question as before please: Do I still need to use only Denali Exchange Data Feed to trade CME with AMP futures or is CQG webapi back by any chance? Thank you very much |
[2024-11-01 23:44:42] |
Sierra_Chart Engineering - Posts: 20197 |
Yes you do . However, we strongly recommend you use Teton order routing instead of CQG: Sierra Chart Teton Futures Order Routing It has no additional cost. And superior order routing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
