Date/Time: Mon, 29 Apr 2024 20:02:39 +0000
Quick question - Custom symbol formula: is (1/{SYMBOL}) or {SYMBOL}^-1 better?
View Count: 234
[2023-04-28 11:50:37] |
User34124 - Posts: 270 |
Just wondering what the best method is for inverting a symbol in a long string, for example 1/US30 * 1/SPX500 * XAUUSD * 1/NAS100 I have checked the documentation especially point 6 which leads to Working with Spreadsheets: Arithmetic Operators But just require some more clarification as my outputs seem to differ, causing me to believe the " ^-1 " being negative could be problematic. Date Time Of Last Edit: 2023-04-29 01:52:09
[2023-04-28 15:11:14] |
John - SC Support - Posts: 31187 |
It should work. The Custom Calculated Symbols use the same calculations as the Spreadsheets do, and the Spreadsheets can handle a negative exponent. What is the difference you see? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-29 01:51:48] |
Ah, I think I had disk issues which caused the errors. Negative exponents tested and works fine. Just to clarify, brackets are used just fine also right? 1/{US30}*{XAUUSD}/(1/{NAS100}) would work like 1/{US30}*{XAUUSD}*/{NAS100}^-1 |
[2023-05-01 15:13:55] |
Parentheses can be used with the custom symbols.
