Date/Time: Thu, 02 May 2024 19:27:44 +0000
Indicator Refresh Issues
View Count: 2315
[2014-06-25 02:07:47] |
cmet - Posts: 537 |
1 Second
[2014-06-25 20:37:49] |
We see the problem and it will be corrected. It is a rather complex issue involving the total volume calculations for a bar when using the Volume by Price study. This only occurs with Renko bars.
[2014-06-25 20:40:51] |
cmet - Posts: 537 |
Okay. However I see the problem on 100 tick bars with a PNF study on them as well.
[2014-06-26 19:38:27] |
Update Sierra Chart to the latest release with Help >> Download Prerelease. Let us know if you continue to see the problem. You should not. Once you confirm that you no longer see the problem, then set the Global Settings >>Data/Trade Service Settings >> Intraday Data Storage Time Unit to 1 tick. That is what it needs to be for Range bars for accuracy. The underlying issue is very complex when the underlying data records are greater than 1 tick for Range bars. We are still working on it but you should not see the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-26 22:58:30] |
cmet - Posts: 537 |
No problem. Thanks for taking care of that.
