Date/Time: Thu, 08 Oct 2026 02:45:45 +0000
Indicator Refresh Issues
View Count: 2998
[2014-06-25 02:07:47]
cmet - Posts: 743
1 Second
[2014-06-25 20:37:49]
We see the problem and it will be corrected. It is a rather complex issue involving the total volume calculations for a bar when using the Volume by Price study. This only occurs with Renko bars.
[2014-06-25 20:40:51]
cmet - Posts: 743
Okay. However I see the problem on 100 tick bars with a PNF study on them as well.
[2014-06-26 19:38:27]
Update Sierra Chart to the latest release with Help >> Download Prerelease.
Let us know if you continue to see the problem.
You should not.
Once you confirm that you no longer see the problem, then set the Global Settings >>Data/Trade Service Settings >> Intraday Data Storage Time Unit to 1 tick. That is what it needs to be for Range bars for accuracy.
The underlying issue is very complex when the underlying data records are greater than 1 tick for Range bars. We are still working on it but you should not see the problem.
[2014-06-26 22:58:30]
cmet - Posts: 743
No problem. Thanks for taking care of that.
