Date/Time: Sun, 13 Jul 2025 07:14:08 +0000
Data Delayed
View Count: 396
[2023-03-07 14:58:53] |
User473031 - Posts: 56 |
My data is being delayed and the message is for me to contact you. I'm using SG I do have AmpFutures account and can show proof if that is what you are needing? I also trade from TOS, would a screen shot of that account be suitable? Michael |
[2023-03-07 16:11:45] |
Sierra_Chart Engineering - Posts: 20186 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
