Date/Time: Thu, 02 May 2024 00:20:51 +0000
Problem with market data
View Count: 173
[2023-03-07 13:17:35] |
User823328 - Posts: 14 |
Hello i have a problem with the market data it's not delayed but look like it's lagging since i have implemented rithmic on data trader service. I have put username and password on trading but i want to use thé Denali data feed that i pay for what i need to write on market data username and password ? In common setting allow support for sierra chart data feeds is ok |
Capture d'écran 2023-03-07 141127.png / V - Attached On 2023-03-07 13:15:40 UTC - Size: 20.3 KB - 40 views Capture d'écran 2023-03-07 141104.png / V - Attached On 2023-03-07 13:15:46 UTC - Size: 25.95 KB - 41 views |
[2023-03-07 13:35:54] |
Sierra_Chart Engineering - Posts: 14173 |
The settings you attached are all correct. Do not change those. Your Sierra Chart account is set to receive real-time data for CME, CBOT and EUREX. Everything looks correct regarding that. If there is lagging data, then refer to: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
