Date/Time: Sat, 04 May 2024 17:25:22 +0000
No feed
View Count: 294
[2023-03-06 17:06:59] |
User344478 - Posts: 144 |
I have no deactivated recurring service. But I do not have the CBOT with market depth for non-professional trading accounts exchange.
[2023-03-06 18:50:47] |
John - SC Support - Posts: 31362 |
Your account is setup with the CBOT with Market Depth for Non-Professional Trading Accounts. If you are having an issue, then let us know what the particular problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-06 18:53:30] |
I have no feed
[2023-03-06 21:35:37] |
Everything on your account shows that you should not be having an issue. The first thing to do is to select Edit >> Translate Symbols to Current Service. If you recently changed your service settings, then you may not have the correct symbols. If that does not solve it, then we will need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-07 17:26:54] |
I did everything you and AMP told me. Until now I don't have feed
[2023-03-07 18:24:06] |
We need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-07 19:13:13] |
I have on Sierra Chart 2457 in green "DF:11 ST:1, 1"
[2023-03-07 19:16:45] |
The feed stop at 19:17:30PM yesterday.
[2023-03-07 23:05:00] |
We still need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
