Date/Time: Fri, 03 May 2024 09:23:46 +0000
Exchange fees
View Count: 242
[2023-01-31 20:21:11] |
User237070 - Posts: 1 |
Hey, I want to trade the emini micros using the Teton Routing service and Denali through Stage5. I currently use VWAP, volume profile, cumulative delta and footprint charts on Service package 5 for delayed data. My question is, which Exchange fee package would I need to subscribe to?
[2023-02-01 15:42:02] |
John - SC Support - Posts: 31334 |
You need to be on Package 11 (equivalent to Package 5) in order to be able to get the real-time data and to be able to trade live. Refer to the following to change your package: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. As to the data, you need to use the Denali Exchange Data Feed and pay the exchange fees for the exchange(s) you need. Follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
