Date/Time: Sat, 05 Jul 2025 18:34:54 +0000
got only delayed stock data
View Count: 365
[2023-01-30 16:11:52] |
User546516 - Posts: 1 |
Hi there, although I have enough credit, all stock related services are activated, I only get delayed data. I've been trying for hours with no result... do someone have an idea to solve this? I'm glad about every hint or input, thanks in advance.... Uwe |
[2023-01-30 21:54:39] |
John - SC Support - Posts: 40745 |
You are using the NASDAQ TotalView exchange, therefore you need to enter your stock symbols with the suffix -NQTV. For example, you need to enter IBM-NQTV. If you just enter IBM, then that would be data from our other feed, which you are not subscribed to, therefore it is not constantly updating. Refer to the notes for the NASDAQ TotalView exchange here: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
