Date/Time: Fri, 26 Apr 2024 09:42:39 +0000
language changing
View Count: 2387
[2023-01-25 18:11:03] |
User494136 - Posts: 1 |
bonjour, desole mais je n'arrive pas a mettre en francais merci de votre aide |
[2023-01-25 21:39:36] |
John - SC Support - Posts: 31131 |
From Google Translate: hello,
sorry but I can't put in french Thank you for your help We do not understand what you are trying to say. Our best guess is that you would like the software to be in French. If this is the case, then there are some things you can do. Refer to the information here: Additional Language Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
