Date/Time: Fri, 26 Apr 2024 16:42:21 +0000
no Datenfeed!
View Count: 183
[2023-01-25 15:17:28] |
T.Gerhard - Posts: 3 |
Hello, I have enabled denali data feed and logged into SC Data-All Service but I am not getting any data! Could you help me please? Kind regards. Gerard |
[2023-01-25 15:27:57] |
Sierra_Chart Engineering - Posts: 14103 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
