Date/Time: Wed, 13 May 2026 10:24:50 +0000
Spreads CME from CQG
View Count: 1080
[2023-01-24 14:08:18]
StephenL - Posts: 122
How does one create a spread chart for F.US.EP (S&P) versus F.US.ENQ (NQ) using CQG data feed?
[2023-01-24 17:13:48]
John - SC Support - Posts: 46104
Refer to the following for how to create a custom calculated symbol:
Custom Calculated Symbols
[2023-01-28 16:39:46]
thanks John
[2023-03-01 11:48:29]
The data on one chart works fine however a second one won't load. The only difference I can see is [CBV-D] written at the top left of the one that wont load.
Any ideas?
attachmentloaded.bmp - Attached On 2023-03-01 11:47:53 UTC - Size: 6.06 MB - 337 views
attachmentNo loading.bmp - Attached On 2023-03-01 11:48:04 UTC - Size: 6.97 MB - 399 views
[2023-03-01 13:33:26]
Sierra_Chart Engineering - Posts: 23747
When posting an image of a chart use this method only:
We will not look at those images you posted.
[2023-03-01 14:02:45]
No problem, here are the two images in the preferred format.
https://www.sierrachart.com/image.php?Image=1677679138961.png
https://www.sierrachart.com/image.php?Image=1677679273385.png
[2023-03-01 21:30:02]
On the FGBX/DB chart set Chart >> Chart Settings >> Symbol >> Continuous Contract to None, then select Edit >> Reload and Recalculate and see if that resolves your problem.
[2023-03-02 07:08:47]
Done. However, still no prior data.
[2023-03-02 17:21:25]
Please go through the instructions at the following link, if you have not already done so:
Custom Calculated Symbols: Resolving Missing Historical Data Issue
[2023-03-06 09:40:01]
I did it again in case but no help. I created another spread FBTP/DB and that works perfect so perhaps it has something to do with the FGBX specifically?
[2023-03-06 18:21:18]
Are you able to get the data for FGBX in a standard chart?
[2023-03-07 07:23:33]
I can, the FGBX is the chart sitting next to it and can scroll back fine.
[2023-03-20 10:42:16]
To tie this off, I have created a new spread chart with the front M23 contracts and the new spread works fine. Ive checked everything and all the settings are the same for both spreads. Strange one. If you want me to check anything else my end for your own queries let me know.
