Date/Time: Thu, 02 May 2024 23:09:25 +0000
symbol format for Hong Kong hang sang index
View Count: 435
[2023-01-23 07:42:51] |
User832613 - Posts: 4 |
Can you create or add a symbol of Hong Kong hang sang index for interactive brokers so that i can recieve the data from IB and plot charts. The symbol in IB is HSI index. Thanks |
[2023-01-23 21:47:03] |
John - SC Support - Posts: 31334 |
This is already in the system. Open the section for Futures on the Find Symbol window and there is an entry for the HSI.
[2023-01-24 14:21:32] |
John, thanks for the reply. what i mean is the Hang Sang cash index itself,not the future monthly contract. For example you have spx-ind-cboe for s&p 500 cash index and you have a separate symbol es-xxxxxx-cme for s&p 500 future. what i need is the symbol of the Hang Sang cash index for IB not the monthly future HSI-xxxxxx-HKFE Thanks |
[2023-01-26 13:48:17] |
So, can you create a Hang Sang cash index symbol for IB? i see that you have many indexes symbols for different international markets under the IB indexes section but i can't find the Hang Sang cash index for Hong Kong.The IB Hang Sang Stock Index symbol is HSI index. Thanks |
[2023-01-26 16:14:18] |
We do not have data for that index. If IB has the data, then you would need to enter their symbol to get the data.
[2023-01-27 04:19:17] |
IB has the data,but i need the correct symbol name on your side in order to create a chart on SC and plot the data on the chart. For example, i have the SC symbol name HSI-202301-HKFE on your side and i created a SC chart with that name then all the data are plotted on that chart once i pressed the command "connect to data feed". But, with Hang Heng cash index,i don't have a SC symbol name to receive IB data. i tried HSI-IND-HSFE and HSI-CASH-HKFE and HSI-HKFE. They all don't work. I need a correct SC symbol name to recieve the IB data. Please help. Thanks |
[2023-01-27 16:34:23] |
Sierra_Chart Engineering - Posts: 14187 |
We do not know what the Interactive Brokers symbol is. You have to figure that out through trial and error. Refer to: Interactive Brokers Symbols We are not going to provide any further help here. If you cannot figure it out, then we cannot either. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
